Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Identificable por el número de modelo S7562, el Galaxy S Duos es un teléfono inteligente con doble tarjeta SIM fabricado por Samsung.
Wifi on my Samsung s duos is not working
When I on the Wifi, it goes into light green mode and does not come into complete green mode[Which is wifi adapter is failing]
Any suggestions on this.
Tried factory re-set but still the same.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 95
6 comentarios
i hav the same problm,,wt can i do nw,i tried so many times its nt workinngggg
- de
mi wifi no funciona se daño solo me funciona con paquetes de datos
y eso no megusta por que es demasiado lento
- de
My WiFi connection is on but connecting any network does not connect and shows saved &secured
- de
My wifi Didn't even turned on.
- de
mobile does not support jiofi hotspot after connecting it show saved and secured but nothing work on it. plz help me why this is happening
- de
Mostrar 1 comentario más
Agregar un comentario
23 Respuestas
Respuesta Más Útil
Dear All,
Wi-Fi Freezing fault may occur due to 10% of Wi-Fi driver related issue and 90% of WiFi hardware fault,
Simply you can use hot air flow to U204 module and check whether it's functioning back to normal
other wise you will have to repalce new U204 Wi-FI + BT module
Here you can find parts for repair
Note : BGA reworking skills required to replace WiFi module
Hope you will be able to fix the fault your self.
Cheers!
Fue útil esta respuesta?
Puntuación 5
Update (09/05/2016)
Puntuación 3
wifi not torning on way
Puntuación 2
dail*#*#526#*#* on your phone keypad this will show a message driver software sucessfully installed than try to turn on wifi this will turn no easily
Puntuación 1
3 comentarios:
It's not working.. can u please suggest me any other solution. .
- de
it's not working ...... can u plz give another way to solve this problem ...
- de
It is not working and can you please any other way to solve this problem
- de
when we on the wifi the siginal ra not displayed on the screen what we should do for that
Puntuación 1
is it your own WiFi signal if it is, is it been set with a password for protection preventing other users connection to your signal?
Update
Usually if it's able to pick up the wi-fi network but does not want's to connect is usually with the secuirity settings. you can try by deleating that as you defalt network and the se-activate it (try to reconnect to it) the default proiblem is usually the security settings.
Puntuación 0
1 comentario:
the same problem occurs on not protected wifi..
- de
yes same my problem on my device
Puntuación 0
sumsung s 7562 wifi not working
Puntuación 0
Yes me too...its feel so annoyed
Puntuación 0
all site are open with wifi but not download any app my phone with wifi
Puntuación 0
Try. *#0011# > Menu key > Select Wifi > Select Power save button Off
Thanks
Puntuación 0
1 comentario:
Tried this but not working
- de
samsung s duos wifi not turning on
Puntuación 0
1 comentario:
- de
How to connect wifi adapter
Puntuación 0
you should heating wifi and bluetooth ic and reboiling it or change it
https://www.google.com.eg/imgres?imgurl=...
Puntuación 0
Wifi on my Samsung s duos is not working.
Puntuación 0
my samsung 7582 wifi is not waking
Puntuación 0
why i cannot turn on my wifi in samsung galaxy duos?
Puntuación 0
I have also same problem....
Puntuación 0
it no working alwayas on and low green
Puntuación 0
My s duos i droped it in water then i put it in rice for a few days then i turn it back on everything worked except wifi and it was on low green. Before the water incident it was perfectly fine
Puntuación 0
This is my problem of my Samsung phone
Puntuación 0
My samsung duos mobile wifi not start
Puntuación 0
1 comentario:
Big ass big
Hgcgjnncgnngcfhjk
- de
My samsung mobile wifi not start
Puntuación 0
Añadir tu respuesta
Sandeep estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 13
Ultimos 30 días: 47
Todo El Tiempo: 78,352
