Saltar al contenido principal
The GravityLight is a gravity generated light source that involves the movement of weights to power a LED bulb.
Why do the bags of rocks not move?
I have filled both bags of rocks and the bags won’t move. I tried to empty out the bags and refill them, but that still didn’t fix my problem.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Stripped gears are the likely cause for the GravityLight to become jammed. Since the gears are damaged and cannot mesh properly, the gears will become stuck. The gears will need to be replaced by removing the front panel and the frame. Instructions on how to access the gears can be found in the Internal Gear Replacement guide.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Jamie Forslin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 367
