Saltar al contenido principal
Released September 2013, identified with model number T100T. 2-in-1 portable with Quad core Intel® Atom™ processor and 2GB of RAM.
Replacing of hard drive
Location, replacement, and largest size that can be on tablet on the Asus Transformer T100
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
6 Respuestas
Solución Elegida
You cannot replace the "hard drive" because it doesn't have one. It has an integrated chip that's solid state. What you can do though, is use a micro sd, and get a OTG (on the go) connector for your micro usb, and connect tons of usb thumbdrive sticks to it, or an external HDD.
Fue útil esta respuesta?
Puntuación 4
3 comentarios:
What if your hard drive is working correctly and the administrator is not functioning
- de
The tablet itself does not have a hard drive. But the detachable keyboard absolutely DOES have a hdd unit.....
- de
I have two of these T100 and neither have a hard drive in the keyboard.. both stuck in bios. When i tried booting the drive it gets error )xc0000001.
- de
Dustin is correct for most Asus T100. But Asus does produce a version with a 500GB hard drive installed in the keyboard unit. The standard unit, without the hard drive, is likely a T100TAM-C1. The unit with an installed 500GB drive is a T100TAM-H2.
I am not 100% sure, but I believe all keyboards are wired for the hard drive, regardless if one is installed, or not. So a hard drive can be added to a unit after purchase.
Puntuación 1
2 comentarios:
Sorry, the ASUS Keyboard dock without an HD are too thin and lack the interface for a har drive.
- de
Those keyboards are only on the latest units, anything more than a year old does have an hdd installed. I am on my second of these, two different types and sizes, and they both had hdd's installed in their keyboard docks.
- de
I believe that the keyboards are interchangeable.
Puntuación 1
I can assure you taht all of the keyboards are NOT the same. Mine does not have the space or the connectors to add a HDD.
Puntuación 0
Well, if it is a model with a hdd, here's a link as to how to replace it.
I was unfortunate enough to have the hdd in my t100ta fail, and this is how you take it out (or perhaps replace it)
Puntuación 0
2 comentarios:
why you were unfortunate , it didnt work ?!!
- de
If a replacement keyboard says T100TAM-H2-GM, as mine does, another keyboard with the same number would not have a slot for a HDD?
- de
The hard drive is located in the keyboard. My Asus Transformer book T100 has a hard drive problem and i found the location of it during the replacement
Puntuación 0
Añadir tu respuesta
Jim Burnett estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 40
Todo El Tiempo: 24,642
