Samsung vs LG compatibility
Hi,
does anyone know if all A1369 polarizer panels are compatible (LP133WP1 TJ A1, A3, A7, LSN133BT01)?
Thx!
Es esta una buena pregunta?
Hi,
Thx!
21dcba, since the polarizer sheet depends mostly on the physical size, they should be compatible as long as the size is identical. You definitely want to make a guide if you change the polarizer. I've only seen it done once and it is not an easy task at all.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 104
