Saltar al contenido principal
A high-end smartphone in the HTC One series featuring Beats audio, released in spring 2012.
Phone will not turn on after update
I have an HTC one S that turned off during an update. It turns on but turns off right after the HTC screen. Do I need a new motherboard?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
Hi,
First try to do a Factory reset (wipe data/factory reset). To enter in the HBOOT menu, remove the battery for around 5s and put it back. Pres and hold the Volume Down button and the Power button at the same time.
If this not help you, you can change the phone firmware from the PC using correct RUU. RUU is a windows program including stock ROM for your mobile. This program will restore your phone to a factory state.
Regards.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Luke estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 573
