Saltar al contenido principal
La más pequeña de los ordenadores portátiles MacBook Air de Apple con micrófonos duales y conectividad Wi-Fi 802.11ac.
Can I upgrade from 4GB to 8GB RAM memory?
I have a MacBook Air 11" mid 2013 that came with 4GB RAM and 128GB hard drive. I want to upgrade the RAM to 8GB so I can run Vmware more efficiently with windows 8.1 and other software that don't run on the mac-side.
Es esta una buena pregunta?
Puntuación 5
Agregar un comentario
1 Respuesta
Solución Elegida
Sadly, no
Apple soldered the RAM to the logic board. You can upgrade the SSD! It's replaceable.
Fue útil esta respuesta?
Puntuación 5
2 comentarios:
Could you replace the entire logic board with one that had 8gb of RAM rather than the original 4gb?
- de
Swapping out the logic board with one that has 8 GB of RAM is possible!
But, the cost factor for doing this then becomes the issue. I would recommend locating a used system which is newer as being a better investment.
- de
Añadir tu respuesta
Rich estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 5,003
