Saltar al contenido principal
Guías de reparación y desmontaje para reparar teléfonos de todos los fabricantes y proveedores de servicios, incluyendo el iPhone de Apple y el Samsung Galaxy. Consigue todo lo que necesitas para reparar tu teléfono tú mismo.
Preguntas 73679 Ver todo
Format Gionee Pioneer P2 without touching screen?
I just dropped my phone into the water by mistake :( I just blow dried it only for a couple of seconds and still I couldn't switch it on. then the next day, i could switch it on at least but the touch doesn't work. Ill have to go to the store and ask them to set this. but before that, I just want whatever is there in the phone memory to be deleted. is that possible? can I format my phone without even touching the screen? I dont want the store guy to go thru my personal data or something. can anybody please help me on this?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 5
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Hi,
This is Android phone. You can factory reset it from the Android System Recovery menu. Usually you can enter this menu by key combination.
Switch off the phone and try: press and hold together - Volume UP + Power ON or Volume Down + Power On or Volume Up + Volume Down + Power On. If you have a camera key, try some combination with it. As you see, the combination must be Someone key + Power On key.
Once you are in the Android Service Recovery menu, with the Volume Up and Volume Down you can choose "wipe data / factory reset". Usually the Power On key is for OK.
You can do this with a PC and ADB Commander too. But the first way is more easy.
Regards.
Fue útil esta respuesta?
Puntuación 3
4 comentarios:
You are so experienced
- de
Mera phone m net on hotae bar bar time service don't aata h
- de
Try to flash the device
You will need SP Flash tool to Flash it
and you can download the file from here
http://repairmymobile.in/flash/gionee-mo...
- de
is it also applicable on P3?
- de
Just check out the working videos in against of it
Gionee P2 Hard Reset
Puntuación 1
Puntuación 0
Añadir tu respuesta
shubhamahapatra estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 10,418
