Saltar al contenido principal
Repair for LED, incandescent, and other handheld electric light sources.
Preguntas 25 Ver todo
Where are the hi/low settings on a Rayz LED Flashlight?
I have a Rayz flashlight.It says it has a high and low setting. how do i use the settings? idem number 180900
1000 lumens
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
1 comentario
We have the same question....no directions with this flashlight and we are unable to get the low setting?? TY
- de
Agregar un comentario
7 Respuestas
Respuesta Más Útil
I finally figured it out (with help) after many clicks and playing around with it. I was starting to assume that it was typo or something on the packaging but the two settings actually exist.
You 1) turn it on 2) gently hold in the power (without it clicking). You hold it in about half-way. It's tricky because both settings are close and hard to tell the difference, but the lo-power is there.
Fue útil esta respuesta?
Puntuación 5
4 comentarios:
Way to go on answering a very tough one!
- de
Sorry, I don't see any difference when following this procedure.
- de
Thanks for spending time figuring it out
mdr903
- de
Kinda repeating what Jason said but I thought I'd give my two cents. My father bought a few of these flashlights and found them at True Value for right at $20 each. Seem to be done decent lights and blows my super expensive StreamLight away. There actually are hi and lo settings but it's barely noticeable. While the light is powered on just gently tap the power button barely depressing it without turning the light off and you're in low setting. Again, the difference is just barely noticeable...
- de
Alright, here's another question on the same item. I own a RAYZ flashite and it's recent decide to BLINK when on and I can't get it to burn steadily? Any idea. I can't seen to find a company website or a distributor on the web.
Puntuación 0
2 comentarios:
I found the distributor (Promier - 815-223-3393) and they are sending me a replacement. There is no fix!
- de
Thanks for the phone #, my unit stopped working and they are sending a new one. Great customer service.
- de
Actually first click is bright on 2nd click is off 3rd click is dim on and it keeps alternating. Try it you will see a slight difference in brightness. Hence the 3 terminals on battery pack.
Puntuación 0
You switch between the high & low settings using the tail switch. One click turns it on to the high setting and rapidly clicking a second time gives you the low setting. However there is not much difference in the intensity between the two settings.
Puntuación 0
Thanks for all the help here, I had the same question. Has anyone found that turning it focuses it all?
Puntuación 0
Does anybody know how many watt the led is?????
Puntuación 0
turn the flashlight on and then press the button again for low beam.
Puntuación 0
Añadir tu respuesta
Mike estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 4,092
