Saltar al contenido principal
The third generation of the Samsung Galaxy tablet with a 7-in. screen announced on June 24, 2013. Repair of this device requires screwdrivers and prying tools. The device is available in white or gold brown with 8, 16, or 32 GB of storage, and includes a microSD slot that can hold up to an additional 64 GB of memory.
Preguntas 120 Ver todo
Why is my samsung galaxy tab 3 always shutting down?
While using my galaxy tab 3 or even when standby in the homescreen, my tab will eventually shut down. It won't turn on again until I press the power button. It always happen. Can anyone help me solve this problem? Thanks.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
6 Respuestas
i have the same problem why?
Fue útil esta respuesta?
Puntuación 0
I have the same problem how to fix it
Puntuación 0
Does it shut down when it's plugged in, or just when it's unplugged? If it works plugged in, then you need a new battery.
Puntuación 0
1 comentario:
it shuts down in both the cases.
- de
I have a problem wirh mine stop responding with games all the time, found that these tables are just a piece of junk, even though I paid to much, I am considering a better tablet of a different brand, and am deffenately going to contact samsung with a complant.
Puntuación 0
bad design
power supply bad designed
batery bad designe
in other words trohw it in to the garbage and buy a new one
Puntuación 0
Hi! If there is a bad electronic component, like a device in short circuit, it will try to start and detects the short, and turns off. If there is a defected charging circuit, it will happen the same or to show dead after a total discharge. OR, and "AND" the last ones, plus if the battery is under the operation level, some models of tablets are not able to start. First step is to charge the battery and to see if the tablet is able to start and charge, or if there is a bad component because there is a wrong behavior.
The following video was recorded for technicians with this kind of problems: https://www.youtube.com/watch?v=2ggQU3E0...
Puntuación 0
Añadir tu respuesta
Jelaine Bernardo estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 1,440
