Is it possible to replace the keyboard?
Keyboard replacing
Es esta una buena pregunta?
Keyboard replacing
If you're a closet masochist...YES provided you can find one. It's much simpler (and even that is a major project) to replace the top case. If you've had a liquid spill as long as the box is open you should check and probably clean the logic board.
If this answer is acceptable please remember to return and mark it.
Fue útil esta respuesta?
Thank you for your answer. Yes. Probably I'am the one. There is no problem with liquids and no any problem with MacBook at all. I want to change keyboard because old one has no Russians letters. I already found a new one. I don't anderstend what's next on this photo https://d3nevzfk7ii3be.cloudfront.net/ig... ? Is the keyboard glued to the Al top? Need I to remove battery to change keyboard?
They are not glued but riveted. You'll have to replace the 100's of rivets with tiny screws.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,294
