Saltar al contenido principal
Guías y soporte para varias marcas y estilos de TV.
Preguntas 8250 Ver todo
Sony Bravia KDF50E-2010 50" LCD HD TV won't power on?
Hello,
I have a Sony Bravia KDF50E-2010 50" LCD HD TV. The red light flashes three times.
What shall I do or what part should I purchase to fix on me own Sony Bravia 50" tv?
When I try to turn it on first green light flashes about 25-30 time. Then I get one red light and the other red is flashing 3 time (continuesly).
Is it worth and possible to fix?
I will be really grateful for your help!
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Martin Hawrylo,
If your television is not turning on or showing any signs of life, see the Insignia NS-24ER310NA17 Will Not Turn On problem page for possible causes and solutions.
This error can be caused by a bad bulb, or a bulb that is not tightly secured as well as the the lamp door isn't tight. Check on those things first. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Martin Hawrylo estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 437
