Saltar al contenido principal
A swimming pool is a container filled with water intended for swimming or water-based recreation.
Preguntas 9 Ver todo
pump just hums
i have a summer escape pool and the pump just hums what can i do to fix it
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
KATHY, there are a few possibilities. Chance of a bad motor start capacitor ( use a multimeter or capacitance meter to check that) a seized pump motor (unplug the pump and see if you can turn the impeller by hand) or a short on the start winding of your motor. We could possibly give you a bit better info if we would know what make and model your pump is. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
The pump has a tiny plastic fan blade which moves the water thru the pump the blades in your fan are broke replace the punk
- de
bang on the motor with a hickory stick, it that doesn't start it, it is the capacitor, replace or bearings, then have to replace the dry end or motor. 35 years in Biz
- de
Most likely is a bad pump motor start capacitor
Puntuación 0
Añadir tu respuesta
KATHY estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 601
