Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El BlackBerry Z10 es un smartphone con pantalla táctil desarrollado por BlackBerry, anteriormente conocida como RIM.
replace non working camera
Internal camera not focusing. Two thread size purple haze across image on rear facing camera. Unable to focus. Front camera clear. Phone dropped often. No lense damage visible. No cracks visible. Purple haze looks like internal cracks?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 6
4 comentarios
not working camera
- de
Yes it's. My BlackBerry camera has stopped working more than a year.
- de
happy if it be fixed
- de
I got it fixed but now it captures low quality images
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
frank, I would download the BlackBerry Virtual Expert from BlackBerry World or go into Help and select Testing, which will allow you to use BlackBerry Virtual Expert without downloading it. With that you can test each feature in your BlackBerry Z10. Check both of the cameras with that. Also make sure that your software is updated. If your camera should be faulty use this teardown to see what is involved in changing it. The camera is not very expensive and can be purchased from places like this as well as many others. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
frank estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 16
Todo El Tiempo: 2,389
