problem while opening the screen
i wanted to open the screen with the suction cup but it doesnt lift the whole display , it just lifts the front glass..
what should i do ?
Es esta una buena pregunta?
what should i do ?
Check out the instructions for opening the iPhone 5 here: Reemplazo de la pantalla LCD del iPhone 5.
There are several steps you'll need to do before completely removing the screen, As the above guide notes in Step 5, "Do not try to completely remove the front panel assembly from the rear case, as there are several ribbon cables still attached at the top of the iPhone."
Fue útil esta respuesta?
Hi there insert a small blade to the bottom left and pry the plastic corner out then you can use a plastic opening tool to pry the rest of the plastic out.. I never use a suction cup
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 7
Todo El Tiempo: 112
