Why are these HDD connectors not the same?
Here is the computer connector and the hard drive. Why are they different?
Es esta una buena pregunta?
Your Toshiba unit uses a PATA interface for it's hard drive. Sadly, the drive you have here is a SATA based hard drive which is a newer standard.
These drives are not interchangeable as you have discovered these use very different connectors.
Fue útil esta respuesta?
Thank you!!!
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 129
