Saltar al contenido principal
The Samsung Wave II S8530 (or "Samsung Wave II") is the Successor of Samsung Wave S8500 smartphone running the bada 1.2 operating system designed by Samsung, which was commercially released on October, 2010.
Preguntas 7 Ver todo
How can I do a master reset without previous owners pin code?
Hi. I got a samsung wave s8530 from ebay and it wont let me master reset without previous owners pin code. It is running Bada 1.2 and I tried a few tricks like volume button holding with home button etc to get to a menu screen but no luck, think some techniques work just for androind OS ?
Can anyone help??? Thanks
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
3 Respuestas
Solución Elegida
Hi in the end i tried all the various pin coses without success. But finally managed it by plugging into computer and using the samsung kies program. Thanks
Fue útil esta respuesta?
Puntuación 1
Respuesta Más Útil
If you can't get an answer from the previous owner, file a complaint with eBay and send it back and leave negative feedback for this seller.
Puntuación 3
justin, try this. Remove your SIM and Memory Card, then dial *2767*3855# (here are two other codes that you can try if the first one does not work *7465625*638*00000000*00000000# and #7465625*638*00000000#) and wait till the phone reboots. If that does not work, you most likely will have to flash your firmware. For that, check on here. Hope this helps, good luck.
Puntuación 2
2 comentarios:
I have similar problem with my s8500. Everythink was exellent. But why to not set up password...? I did it. Whats happen next? I forgot it. Phone was wait for new battery and I forgot password.
After restart, phone asking me for password. Its 8 digits max. No accept #. That your suggestion is wrong. Its not full keyboard accesible. Only 8 signs.
- de
Same problem with my Wave 525 S5250
- de
Añadir tu respuesta
justin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 8,185
