Saltar al contenido principal
¡Los auriculares estéreo Skullcandy Skullcrushers Subwoofer en Black Pinstripe literalmente bombearán la música directamente a tu cabeza! Estos poderosos audífonos cuentan con un amplificador de bajos en línea ajustable y altavoces con los primeros subwoofers vibratorios incorporados en la industria. Puede ajustar la cantidad de efecto de graves con la rueda de control en línea.
Preguntas 11 Ver todo
How to fix or replace headphone Jack?
I own a Skullcandy Skullcrushers head phone that has recently had problems with the jack of the unit.
The issue is where only the left ear speaker functions properly at all times while the right is silent unless the wire on the jack is moved to a "Sweet Spot" where functionality returns until the wire is moved from the new position.
My question is weather or not it is possible to fix or if not, replace the jack all together. What would be required to replace the jack and what wire placements are for the left and right ear respectively.
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
abyssalshaman, yes it is. Check this guide on how to replace the jack. This is a good set of headphones and relatively easy to repair. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Thanks so much Oldturkey03! I love these headphones and would rather replace the jack for a fraction of the price it takes to buy a new set haha :)
- de
Añadir tu respuesta
abyssalshaman estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,672
