Saltar al contenido principal
Unidad de flash para usar con cámaras Nikon
Preguntas 12 Ver todo
My flash does not turn on at all after it fell.
So I have this nikon Sb600 which dropped on to the floor flash tube/head first. It was carpeted floors. Now i have open it up and i could see nothing was broken; not the flash tube it self. Online they were talking about the battery contacts being recessed after a fall. I hook it back up and still have not fix it. It is already out of warranty and nikon service repair is more likely 75-90% cost of a brand new one. Would like this to be fixed since i'm a broke college student. Any help is greatly appreciated!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
2 comentarios
i got it repaired at mata electronics Bangalore please contact them at mataelectronics@Gmail.com for further assistance
- de
How much did it cost?
- de
Agregar un comentario
7 Respuestas
Respuesta Más Útil
If you poke around the net, you will find the parts and the service manual. Try looking for "SB-600 parts list" and a similar search for the service manual.
- Usually it is the tube that is shot int he SB-600 after it falls down.
- Nikon's parts department in the US will sell you a new tube (part # XE701) for about $11 + shipping. You need to be adept at soldering to replace it
- a simple test to determine whether the problem is on the tube end is to use a voltmeter to measure the flash capacitor voltage. It should be about 300V DC. Look in the service manual where they show you how to discharge the capacitor- use the same contacts to make the measurement.
- if all else fails, a broken SB-600 goes for $40-90 on Ebay!
D
Fue útil esta respuesta?
Puntuación 3
I bought a broken one of these for $50 with the hope that I could fix it. It had fallen about 3 feet and was totally unresponsive after that. I just finished pulling it apart and I found a couple components on the PCB that have broken solder joints. Unfortunately they're all SMD and are going to be next to impossible for me to fix.
So the moral of this story is carefully inspect all of the PCBs for issues. Also I will be uploading the repair manual to demonoid shortly.
Edit: Here's the guide I made, and the repair manual has 16 seeds on demonoid.
Puntuación 2
1 comentario:
Hi Chris..why don't you take some photo's of the disassembly process and make a guide here? Cameras are a pretty popular repair area and we need some more, and if you've knowledge to share it'd help loads of us! If you post the photos of the parts that are broken someone may be able to help you.. are you any good at soldering?? I'd take a chance or pop to your local t.v. repairman and see if he'd do the work..
- de
Were there any loose parts? Also I doubt if Nikon would fix this if you opened it up, but you can try.
I've been sitting here for like 5 minutes trying to think about what can go wrong, and I only came up with, anything really. Well of course the problem has to be in the circuit because the flash doesn’t even start up.
You’re best bet is buying a third party i-TTL compatible flash, or a used SB-600. You can also try to send it in to Nikon
Puntuación 0
Hi,
I have my an SB600 who had the same problem. After dismantling it is on the main PCB (with the control screen) a L301 self beside the D301 diode on the right lower side of the PCB which is detachment and prevents the start of the flash.
There is a need to have an iron welding for CMS!
I have the pdf of the service manual
Ringeisen
France
Puntuación 0
I have a similiar problem, but the flash did not fall, it just stopped emitting light. Nikon in France will not sell a new light tube but only repaird the unit....far to expensive! Any ideas of where one can buy a replacement tube Or could this be another problem. I opened the unit and measured 300dc across the flash tube!
Puntuación 0
my flash model is nikon sb900 , the flash did not function totally.
Puntuación 0
I had the same problem and this repair video was exactly my problem:
https://www.youtube.com/watch?v=RTVwZ976...
If you have can borrow solder iron the repair is free
Good luck
Puntuación 0
1 comentario:
Hi,the tubes are easily found on aliexpress for cheap. we also easily find the tubes for studio flash on aliexpress.Ils se soudent trés facilement.Attention ne pas oublier de decharger le condensateur c'est trés violent et douloureux .once the repair done do not forget to do a reset
- de
Añadir tu respuesta
Lucas C estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 12,145
