Saltar al contenido principal
Modelo A1059 o A1099 / disco duro de 20, 40 o 60 GB / rueda de clic sensible al tacto
Preguntas 20 Ver todo
Why does my iPod show a folder with a warning sign?
My iPod shows a folder with a warning sign and below it the words www.apple.com/support/iPod. What could the problem be and how can it be fixed?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
3 Respuestas
Respuesta Más Útil
normally that would mean that the hard drive of the iPod needs to be replaced - any clicking sounds in the past ?
Fue útil esta respuesta?
Puntuación 1
3 comentarios:
please click here - expecially the posting that is shown first (you should read the rest too - but this one could be important
- de
since the link i wanted to add is a little bit censored, i can only recommend you a googe search with: "iPod diagnostic mode" <- use it incl. the " - the first result should give you some informations about the diagnostic mode and how to verify your harddrive without the use of a computer
- de
good answer +
- de
Go to www.apple.com/support/iPod like it says.
There are several different warning signs that Apple uses. Please take a look at this link: http://support.apple.com/kb/HT1378
to identify which one you have and the probable fix.
Puntuación 1
1 comentario:
fresh research +
- de
Why do I have a triangle warning that says NO COMMAND?
Puntuación 0
Añadir tu respuesta
Eikel Weston estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 2,529
