Saltar al contenido principal
Lumia 625 completely dead after digitizer replacement
Hi there,
II replaced a digitizer on a lumia 625 today.
The phone was working fine when it came to me, just had a cracked digitizer.
After the repair, the phone would not power back on. No signs of life whatsoever.
I have a wall charger for USB devices that has LED lights that indicate when the power is going to the device and those LED did not change colour when i connected the Lumia 625.
The computer did not detect the device either.
I put the original (cracked) digitizer back on the phone but still no life.
I have tried all the combinations of keys for soft and hard resets but still no response whatsoever.
Has anyone had any similar problems with the Lumia 625 or any lumia for that matter?
can anyone please shed some light on this for me ?
thanks
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario:
hey guys, got mine a new flex cable, battery and the charge dock board from ebay, replaced them but the phone cannot even start, or charge. I really cannot dump this phone. i need it working
Any help i will appreciate
- de
Agregar un comentario
3 Respuestas
The flex cable is damaged then. Need to put in a new flex cable
Fue útil esta respuesta?
Puntuación 0
3 comentarios:
thanks, which ribbon though ? the digitizer ribbon and the battery ribbon are attached to their respective parts
- de
The ribbon that connects the two motherboards and the start and volume buttons. it's glued to the frame and even the smallest of crack can break it.
- de
again, thanks for all your help much appreciated.
I will try replace this ribbon, bt could you possibly link me to somewhere that sells it ? I don't really know the technical name for it and I have tried entering "lumia 625 motherboard ribbon" into ebay with no results. So do you know the proper name for it ?
I'm in Ireland BTW
thanks
- de
hey plz parcel it to me...iif you there then mail me on vishavjeetrana786@gmail.com
Puntuación 0
Hi it happened to me today tried all what you did but no sign of life
then when i checked under microscope i found one broken capacitor next to headphone jack the top one is broken
its L2004 in schematic
i think it happened when i tried to remove the board out
i don't know from where i can buy this capacitor if anyone knows anything about it plz put some light on it i will appreciate
Puntuación 0
Añadir tu respuesta
smithbyrne estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 4,890
