Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3530 Ver todo
Can the iPhone 5 battery be used in iPhone 5S?
I have an iPhone 5s that was water damaged. I have cleaned it up and don't see any residue or corrosion. However, the phone refuses to charge, and I am thinking it may be the battery that needs to be replaced. However, I can't find the iPhone 5s battery for sale in any reputed places (e.g., at iFixit).
Question: can I use the iPhone 5 battery in iPhone 5s? Are the connectors the same? I know the capacity of the 5 battery is about 8% less than 5s battery, but that should not be a huge issue.
Es esta una buena pregunta?
Puntuación 2
3 comentarios
no, they are totally different connectors, i know cause i made the same mistake, and had to purchase another battery....THEY NOT THE SAME
- de
I have a problem with my iphone 5. I just had the battery replaced about 5 months ago and the charger chord was working fine with it then.
Then about a month ago, I bought a new charger chord and it worked fine for less than a month.
Now the phone won't charge with that new chord when plugged into the outlet. Even when I tried numerous chargers, it still doesn't charge. So, I'm beginning to think that the person who replaced my battery gave me the wrong type of battery.
The other day at that place, the guy there said that there shouldn't be that much of a difference. I think he just said that because he didn't feel like replacing a battery at that time.
I'm gonna go back and let him know that there IS a difference between the two batteries and that I want it changed again without being charged.
- de
Hi does the battery iphone 5s putted in iphone 5 then it work ok or not?
- de
Agregar un comentario
6 Respuestas
Solución Elegida
No,the connectors are different
Fue útil esta respuesta?
Puntuación 7
3 comentarios:
Are you sure? I am looking at the connector images on some ebay listings for 5 and 5S and they look the same.
iphone 5S:
http://www.ebay.com/itm/1560mAh-Li-ion-B...
iphone 5:
http://www.ebay.com/itm/OEM-1440mAh-Li-i...
- de
I am sure. Look at the ifixit teardowns
- de
i5 has a 5port connector and a 5s has a 4port connector.
- de
If ebay pics are the same it must be true... NOT
Puntuación 3
1 comentario:
Most of the time eBay shows the earliest or latest model pics for example what the find off the internet don't always believe them also when you click on a listing make sure it's not got sub menus as that's properly where your going wrong
- de
Yes, of course you can take the connector off the old battery and re-solder it onto a new one. TIP: Before starting the process, make sure you are wearing goggles, a Fireman's fireproof suit and fireproof gloves, (you'll need the special ones with fine, fireproof material fingers, so you can still manipulate the small connector) - Oh, and check to make sure your house insurance is up to date, and not invalidated by you doing something totally and utterly stupid! Have fun and ask your Mum to put a post on this messageboard when she gets back from the funeral, to let us all know how it went!
Puntuación 1
iPhone 5 battery: 1440 mAh, 3.8V, 5.45 Watt Hours.
iPhone 5s battery: 1558 mAh, 3.8V, 5.92 Watt Hours.
Puntuación 0
cant used batty of iphone 5g by iphone 5s because its deffrint conector also
Puntuación 0
From what I've seen 5 needs a 5 and 5c and 5s use same battery just what I've seen on e bay anyways
Puntuación 0
2 comentarios:
Can't you take the connection off the old batter and solder the old connection to to new battery
- de
@nicholasvotolato Nope. Some of the lines are completely different, or non-existent across different batteries for different model iPhones.
- de
Añadir tu respuesta
Cybazaar estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 48
Todo El Tiempo: 104,939
