Saltar al contenido principal
La Jazz HDV178 es una elegante videocámara de mano de apuntar y disparar con una resolución de video de 10 megapíxeles y capacidades de imágenes fijas de 11 megapíxeles.
Preguntas 3 Ver todo
Is my battery defective?
As with the first question I too am having trouble using my camera. I hook it up to charge and red light flashes briefly then goes solid gree, how ever when I try to use the camera it seems the battery is dead. In order to determine if it is a defective battery I have to try a new one. Where can I get a new battery.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Dick Rutter, from your description alone, it does sound like your battery is no longer holding a charge. I would start with that and hopefully it will resolve it. Otherwise there are issues with the charging circuit. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 1
Hello
If the battery voltage drops, eg, 3.25 V, the camera will not start. then it seems that the battery is bad, which in many cases is so. But it may be that the internal battery is no longer charged. The clips on the battery voltage to the camera can be pushed too far inside which there is no good transfer.
You can try to charge the battery. Voltage to 3.7 volts with an external power supply When the battery voltage, battery back in the camera, in most cases, the camera will do it again, for a kotrte time. The battery's going but a limited number of them. A new battery is the solution in many cases.
Puntuación 1
Añadir tu respuesta
Dick Rutter estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 306
