I hear a click as if the adhesive did jack and then let go
after about two months that I glued the glass ipad 3 if I press strong in some points of the frame I hear a click as if the adhesive did jack and then let go ... I can feel comfortable or do I take off again and add the glue? in which case glue can I use? thanks (I state that the glass does not seem relieved than the small plastic seal "bezel")
Es esta una buena pregunta?
Thanks for the reply Joshua, I'm sure that the 'LCD is fully assembled. I'm a fairly accurate and this will be at least one twentieth ipad dismount, only just a few times the digitizer does not adhere perfectly right .. of course you have to press very very strong to notice the problem, and I realize that the aftermarket will not be as double-sided the original apple ... but I was wondering why ... andrea
- de AndreaBaglione
