Saltar al contenido principal
Procesador G5 1.6, 1.8 o 2 GHz
Preguntas 130 Ver todo
Upgrade PowerPC iMac to Intel processor
I have an early 2005 iMac G5 with a PowerPC processor. Can I replace the logic board and whatever else to upgrade to an Intel processor so that I can use the newer 10.9 OS?
Update (01/23/2014)
Thanks for the info Dan. I'm having start-up problems, tried all the recommended quick fixes that I found here, but it still won't work. Maybe an Apple tech can fix it.
Update (01/24/2014)
The power supply looks good, the 1,2 & 3 internal LEDs light up. Not sure about the hard drive. It seems to run OK and the Apple Hardware Test passed. I ran Disk Check and repair from the Install Disc, erased and reloaded the OS and tried many other startup suggestions. I replaced the back-up battery and reset the SMU and the PRAM. It will boot from the Install Disk but will only boot in Safe mode from the HD. Am trying to get a friend to hook up by fire wire to see if it will boot that way. I will take it to a technician if parts need to be replaced. The machine is not used very often and I hope to not have to spend big bucks on a new one.
Es esta una buena pregunta?
Puntuación 0
2 comentarios
Is the HD going? Or is the power supply getting flaky? There is a know issue with the power supply caps blistering and failing.
- de
I would set your mac up in Target mode and then run disk utility running the repair permissions & then disk options from your friends system. Male sure you have a backup just in case!
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Sorry, not really. The internals are radically different between the PowerPC & Intel models. Besides the cost and labor would be much more than buying a new unit.
While I'm sure someone has created a iMac bodied Hackintosh, it would be for the fun of it like people do with cars. It wouldn't be sellable afterwards.
FYI - Many people loved the Power Macintosh G5 cases for creating Intel/Windows (cough!!) systems and I know of one person that created a Power Macintosh G5 cased Hackintosh.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Dwight estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 2,666
