Saltar al contenido principal
Modelos de MacBook Pro con una pantalla de 15"
Preguntas 8262 Ver todo
How to recover my deleted files
I accidentally deleted some files (actually it is a folder which is including word, excel related to my study and some pictures of my families) and clean up the trash. I want to get them back. I am using Macbook. Is there any way to do that?
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
10 Respuestas
Solución Elegida
Restore from your backup.
If you have no backup a 3rd party Disk Recovery Tool might recover some or all of the data but you must stop using the machine now.
The trashed files are now available for your system to overwrite them. Once they are overwritten it's prohibitively expensive to recover the data.
I've had success using Data Rescue 3 (there are other Mac OS data recover applications)- you must have a "recovery drive" (not your main drive or drive you a scavenging from) on which to save the recovered data. You boot from the Data Recovery disk (system)
Apps can be reinstalled.
If this answer is acceptable please remember to return and mark it.
Fue útil esta respuesta?
Puntuación 2
Try data recovery tool like Disk Drill Mac Data Recovery or Stellar Data Recovery to recover your deleted files
Puntuación 1
You can use third-party software Kernel for Mac Data Recovery Tool. It can efficient to recover corrupt, damage, or deleted picture and images. Reference link : http://macintoshdatarecoverysoftware.blo...
Puntuación 0
1 comentario:
Jameshsmith91 - 'Have you successfully used linked the software? a yes or no would be helpful.
- de
You can opt for any data recovery specialists available in the market for this task. Some of them guarantee the results.
http://www.aberdeen-datarecovery.co.uk
Puntuación 0
1 comentario:
Tony 0'Hare 'Have you successfully used linked service? a yes or no would be helpful.
- de
Trash bin is also a folder on mac system, you can only scan the system volume with mac data recovery software. And please remember don't use you mac again till the mac data recovery software get back your lost files.
Puntuación 0
It’s happened to the majority of the Mac users: deleting a file, folder or entire disk, then realising that you’ve made a mistake. You reach for your backup – and you don’t have a backup. What now?
To solve such type of data loss problem, there are plenty of utilities to help recover deleted files under Mac OS X. Although, your chance of success depend on how the files were deleted from the system and what you’ve done since then. Unfortunately, you will also lose some of your original filenames, though some reconstruction is possible.
All Undelete utilities require the use of a separate recovery disk to which are copying the recovered files. The recovery disk needs adequate free space for the expected amount of data. A hard drive, flash drive, another Mac in Target Disk Mode, or even an iPod, can be used to store recovered files.
There are some utilities available for this task, the two I’ve relied upon are Mac Data Recovery Software and TestDisk. Both are often worth having around in crisis situations; sometimes a few files will be found by one but not the other.
Puntuación 0
If you empty the Trash the files are gone. If a program does an immediate deletion rather than moving files to the Trash, then the files are gone. Data recovery is possible but you cannot process any additional writing operation to the hard drive but just shut your computer down. Actually when we delete files, the files themselves are not really erased-only the directory entries are deleted. The space which was occupied by the “deleted files” has been returned to the system as available for storage, but in fact that the “deleted files” are still on the drive. But if you write any data into the drive will overwrite the space of the "deleted files" and these files will be lost permanently. Also if you save a file into the hard drive with the same name of one file which has already put into the drive, the old one will be overwritten by the new one and cannot be recovered.
Maybe you can try uFlysoft Data Recovery for Mac, it can recover empty trash on Mac only in three steps:
Step 1. Launch the software to scan the device where your files deleted
Step 2: Preview the scan result files and make mark if it is the one you find
Step 3: Recover files
Puntuación 0
If you are using Macbook, you can try download Bitwar Data Recovery Software, I found it useful and easy to recover lost data, expecially you accidentally delete it from your computer. It wouldn’t be a big problem by using this software. Have a look!
Puntuación 0
Whenever you deleted a file, you just remove the entry instead of the file itself. First, the space of this deleted file will be marked as "available" for writing new data. That's the key point why you can apply tool to trace the deep entry and eventually find the raw files!
Accordingly, once new data occupies the marked area for "available", it's getting hard for any piece of software on the market to retrieve replaced and overwritten files. That's it. The sooner you find data recovery solutions, the more deleted files you can get back.
In here, I recommend MiniTool Mac data recovery for your case.Which can hopefully recover deleted files from an emptied trash bin, a formatted hard disk, a crashed operating system and even a virus-infected Apple computer.
Hope that helps.
Puntuación 0
Yes you can do it with the help of data recovery specialists who provide MAC recovery services.
Puntuación -1
Añadir tu respuesta
judychristina estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 1,517
