My fn key is stuck
so the key on my multi purpose keyboard on a g4 mac powerbook, everytime i press the k button i get 2 instead of k...
so i think it is the fn key but i can press it but it doesn't respond
Es esta una buena pregunta?
Did you spill something into it?
You could try cleaning the mechanism by popping off the key cap and you can try taking it apart to clean the logic board contacts. In either case you'll need to use distilled water with a cotton swab (Q-Tip) to wash the areas down. Then go over the areas again this time with a high grade of Isopropyl alcohol (85% or better)
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 117
