Saltar al contenido principal
Publicado en Japón el 12 de diciembre de 2004, en Norteamérica el 24 de marzo de 2005 y en Europa el 1 de septiembre de 2005.
Preguntas 20 Ver todo
PSP backlight not working
I have a PSP 1000 and the problem is the back light. I tried replacing the whole screen but the back light is still not working. So I am 100% positive that the problem is actually the motherboard, but everything else is working fine. I have tried the fuse fix but that didn't work either. Has anybody tried grabbing the voltage from another location within the motherboard? any suggestions on where to grab voltage from?
Es esta una buena pregunta?
Puntuación 1
2 comentarios
I did check the voltage where the back light goes and it gives me zero volts, and there is continuity in its proper fuse.
- de
Did you test the points where the back light would get power from with a multi meter?
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Check this video and here great instructions in getting your backlight back. There are multiple fuses on the board, make sure that you check the right one.
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
tehsalt estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 19
Todo El Tiempo: 9,320
