Why is my iPod nano 6th generation not turning on?
even if I charge it or hold the power button for three seconds it wont turn on
Es esta una buena pregunta?
Connect it to iTunes and see if it shows up. If it does, the display needs to be replaced. If it doesn't, it's a logic board issue. Also, for future reference, do not create multiple questions for one problem.
Fue útil esta respuesta?
turns on with cracked screen but does not show up in iTunes.
Took my apart everything worked perfect but the on/off button so I fixed that and put it back w/ extreme caution but the screen turn all white w/ noting on it.
It does connect to I Tunes deletes and add song, plays from it but when I disconnect white screen only and it also does it when I plug the earphone jack aging white screen only
Try seeing if you need to replace the on/off/volume buttons. there is a little spring right under the power button, causing the button to not come back up. Also, if you plug it in with a USB-iPod cable, it should turn on and operate normally until the backlight automatically times out(display dims to conserve energy). This means you need to replace your power/volume buttons (they all come in on part.). Thanks!
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 3,500
