Saltar al contenido principal
Modelo A1059 o A1099 / disco duro de 20, 40 o 60 GB / rueda de clic sensible al tacto
Preguntas 20 Ver todo
Do I need to replace hard drive?
Recently placed my iPod on a slightly magnetized metal plate (a cover for a nook that I think was made magnetic due to the magnetic clasp). The iPod played for several minutes and then shut down. The symptoms are ,click wheel does not rotate,turns on when menu spot pressed. Apple logo comes up for several seconds and then the file folder icon comes on and then the iPod shuts down. I tried restore when connected to a MacBook Pro and the device was not recognized on the iTunes menu. I then tried pressing both the menu and center of wheel as recommended but does not help. The iPod did get warm when the problem first occurred. Any advice greatly appreciated.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
sorethumb, this could be tough one. Yes, I would start with the hard drive and a new battery for sure. Follow these guides for that. The best way would be to test the hard drive first. There are USB to Zif adapter available on ebay that would allow you to test your hard drive. Something like this will work. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
sorethumb estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 127
