Saltar al contenido principal
Which Philips screws on left edge of keyboard area?
In step 28 of the ibook g4 Logic Board Replacement guide, the accompanying image shows which 3 screws need to be removed.
The problem is, those top & bottom left screws are different sizes than the bottom right one. What size screwdriver do I need for them?
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
2 Respuestas
Solución Elegida
Unless they have been replaced with something different, those screws should just be basic phillips screws...any smallish phillips-head screwdriver should do it. I don't know the technical size of the screws, and it really shouldn't matter so much. If they are problematic, I sometimes use a slightly larger phillips, which can give you a better grip.
If you've gotten to step 28, you should already have a screwdriver capable of dealing with those screws, so I get the idea from your question that there's something more to it than that...are they torx screws, or possibly are they stripped?
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Thanks. They're neither torx nor stripped; they are standard philips head, but I think they're size 00 as none of my screwdrivers (0,1,0-2) quite fit them. When you get down to the tiny sizes, it seems that exactitude of fit matters more and more.
- de
Small Phillips-head screwdriver.
Puntuación 0
Añadir tu respuesta
jimryan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,341
