Motherboard BAT500 battery leak.
My Galaxy S2 (GT-I9100) is 20 months old. It's BAT500 battery on motherboard leaked, damaging resistors on motherboard through acid leak. Whether and how to replace or repair it?
Es esta una buena pregunta?
John Shelly, for now I would suggest to disassemble you phone, using this guide. Clean your motherboard and all other affected parts first with a backing soda/sterile water mix. Then use some high grade isopropyl alcohol and clean it again. As for evaluating the damage to your board, and if it is fixable, depends on which parts are damaged as well as your skill level. Post an image with your question so we can see what damage you have. It may give us a better idea of what you are up against. To add images to your question, use this guide.
Guía
Dificultad:
Fácil
2 minutes
Guía
Dificultad:
Moderado
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 2,870
