Saltar al contenido principal
Repair guides and support for small electric personal space heaters.
Why is my eden pure blowing barely warm air?
I have a eden pure 1000xl heater. It is blowing out air and working well but the air is only about 75 degrees.
I can see the light is on but it is not very bright in comparison to my other eden pure heater. Is this a bulb issue? I am extremely handy but before opening the box I am looking for knowledge. The unit was manufactured in 0907.
Es esta una buena pregunta?
Puntuación 5
2 comentarios
How to know if bulb is bad
- de
My eden pure was only blowing cold air...so i bought all new tubes and put in it but it's still only blowing sorta warm air? I don't know what to do please help!
- de
Agregar un comentario
3 Respuestas
Solución Elegida
The element is most likely burnt out. Here's a video on repairing it: http://www.youtube.com/watch?v=tSTHbLrUp...
Fue útil esta respuesta?
Puntuación 2
If your EdenPURE 1000 XL is only blowing warm air, that is certainly a sign that one or more heating element bulbs need replacing. You can watch a video on this page that provides a step by step guide on replacement the heating elements in your heater. It’s very well done and the individual who provides the demonstration is an authorized edenpure parts dealer.
Puntuación 2
3 comentarios:
Not only is it blowing warm air, but the fan speed is slower than usual as well. Is this still a heating element issue?
- de
I have the same issue as Robert S. How can I fix this?
- de
My blows cold air on one side and warm on the other side is that the way it should work or not
- de
My Edenpure is making a high pitched whistling sound and after about 20 minutes, it cuts off. One time it kicked a breaker. What's up? What should I do?
Puntuación 0
1 comentario:
If you're edenng pure heater is making a high-pitched whistling noise after about 20 minutes it sounds like the bearings on the fan are out, causing the motor to trip the breaker. Replace the fan.
- de
Añadir tu respuesta
mike estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 16
Ultimos 30 días: 71
Todo El Tiempo: 35,477
