Saltar al contenido principal
Why does the receiver turn off after pushing the power button on?
So when I turn on my Receiver from Standby mode it briefly powers on then makes a signal noise error like you are watching static television then the Receiver turns off and a Red Ring flashes around the Power button. I have tried opening the tv hutch door where the Receiver is at to give it more ventilation because I think that could be a possible culprit. Does anyone know anything specific to this brand or model?
Denon AVR391
Es esta una buena pregunta?
Puntuación 4
4 comentarios
When I turn on my receiver it lights up then goes out
- de
Can it b a fuse
- de
It can be a speaker wire connection, pull one wire at a time while switching the unit on and off.
- de
No speakers hooked to mine and it still do it
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Sounds like the unit is going into protect mode. There are a few causes for this. First unhook all the speaker connections. If it stops doing it then, there must have been a short in your speaker cables or speakers. If it continues to go into protect mode you either have a blown power amp or blown power supply(maybe a bad digital boards, but thats highly unlikely). That will have to be serviced by a professional. If the unit was not receiving proper ventilation to begin with chances are it overheated and it caused the current failure. Sorry to hear about your issues, I hope you fix them.
Fue útil esta respuesta?
Puntuación 3
3 comentarios:
I have two radios they both were in storage for 5 years now both don't work power on for 2-3 seconds then turns off.
- de
how can i fix it my self
- de
My zenon plays for a minute then shuts down with a red light around the on off switch
- de
Añadir tu respuesta
Nephew estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 15
Ultimos 30 días: 54
Todo El Tiempo: 23,108
