Saltar al contenido principal
A phablet style smartphone with stylus, released by Micromax Mobile in 2013.
Preguntas 17 Ver todo
Micromax Canvas doodle 2 not getin switched on..? HELP..!
Oh god am so stressed ..my smart phone Micromax canvas doodle 2 which is just 25 days old (bought it 25 days back) was working just fine then i look away for a minute and it did not start at all,cant charge,nothing!even the light that indicates its charging is not seen ..am pretty sure its not the battery because
a moment before i plugged off the charger coz battery was full..i really dont know what to do....will i get a replacement from company???plz help me......please anyone who can help me you'd be saving my life..anyone..please......
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 29
25 comentarios
yes,the same problem occured with me on my new canvas doodle 2 . please can anybody help
- de
same error with my phone
- de
same error wd mahh phon
- de
tysmmmit reallly worked for me guyss another thing you have to hold it for 2 3 mins n it gets startd
jusst have some patience
n dunn panic
- de
- de
Mostrar 20 comentarios más
Agregar un comentario
7 Respuestas
Respuesta Más Útil
the best thing is that restart ur phone with (lower volume key + power bottun) and ur phone will be restart...
Fue útil esta respuesta?
Puntuación 6
17 comentarios:
thank you ... it worked ... thank u
- de
Guys thanks a lot, even my phone had a same issue. Cheers.
- de
Somebody plz help me..my mobile is canvas hd and is not switching on, got stuck on screen logo.
its been 30 hours. EVEN i tried power key + lower volume button but it is showing Recovery mode and factory mode. I done everything but still got stuck with the same.
plz tell me what to do ?
Plz help .....m in Australia..very hard to get care centre for me....
Megha
- de
Thank u.. it is working now....
- de
i need someone to help me my macromax canvas a121 is off and is not on pls someone should help me
- de
Mostrar 12 comentarios más
The same thing happened with me on micromax doodle2 ..... the fault is of the mother board , the mother board has malfunctioned due to some corrept file downloaded! Go to the nearest service center and tell them the problem !
Puntuación 0
contact on the number provided in the box of doodle 2.
or try this...
press the volume key (lower volume key) and the power button at same time..
the phn will restart..
this may work...
Puntuación 0
lower vol key + power on button, keep pressed for some time, it RESTARTS.
If it doesn't work for the first time, try again it worked on the second time for me.
STUPID PHONE. very unreliable. Just GIVES UP ON YOU and at the WORST TIMES !!!
I wish I had bought a SAMSUNG GRAND.
Too Late Now. Spilt Milk.
Puntuación 0
Go to setting-> Factory data reset
you have an option of back up data as well as autoomatic restore while reinstalling.
Depends on ur requirement check uncheck these and click factory data reset
Puntuación 0
Worked for me as well. Keep -vol & power buttons pressed simultaneously for some time. I had to press almost 15-20 seconds before the screen appeared. Thanks.
Puntuación 0
2 comentarios:
After pressing lower vol key and power buttons it shows recovery mode : volume up and factory mode : volume down. But after pressing volume down key its not starting up, should I press power button as well or only volume key for factory mode ?
- de
same problem with me too.. I have tried everything but nothing seems to work for me ..help somebody...
- de
press volume + key and hold for 30 to 35 sec then i will switched on dont worry...
Puntuación 0
Añadir tu respuesta
Nishant estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 73,592
