Saltar al contenido principal
Lanzado en junio de 2012 / Procesador Core i7 con Turbo Boost / Hasta 1 GB de RAM de video DDR5
Preguntas 600 Ver todo
Logic Board Repair 625 9AHRTZ possible?
I posted earlier about my wine-damaged MacBook Pro not powering up or charging after a full cleaning proces. I've identified the fried component on the logic board.
The component reads: "625 9AHRTZ F2__SC"
Can this component be replaced by a skilled technician? Do you see any other fried components? Could it return to life after replacing?
Here are some photos of the board:
http://imgur.com/a/w4qJw
Es esta una buena pregunta?
Puntuación 4
Agregar un comentario
1 Respuesta
Solución Elegida
Alex, that is reference designator U7000 and it is your "battery charger". The proper description is ISL6259 in a TQFN package and it is Intersils integrated battery charger controller for Li-Ion/Li-Ion polymer batteries. Amazingly enough it is not stocked at Mouser.com or Digikey.com, but it is available at places like this. It can be replaced, if one posses the right skills and the right tools but "Due to the excellent thermal characteristics of this mounting package, it is very hard to rework the device, as hot air reflow typically does not offer enough heat to the thermal pad without damage to surrounding board material or parts. Oxidation of the exposed chip contact pads after being exposed to a reflow oven during initial assembly makes solder wetting to them during rework quite difficult. Additionally there is no clearance for a soldering pencil to reflow pads under the chip if touch up is desired." from here. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 7
5 comentarios:
Thank you very much for your response and references.
- de
so if you lived at a different country how its possible to be fixed????
- de
@triborgbrap you would repair it the same way. I am not sure which part you are having trouble with ? Parts? Service?
- de
you know anything about IC chip???
- de
625 9AHRTZ need to be replaced that's the problem
- de
Añadir tu respuesta
Alex estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 8
Ultimos 30 días: 38
Todo El Tiempo: 9,220
