Saltar al contenido principal
Linksys WRT54G (y variantes WRT54GS, WRT54GL y WRTSL54GS) es una puerta de enlace residencial con capacidad Wi-Fi de Linksys.
problem with router connection
Dear Sirs,
I have the following problem with Linksys router wtr54gl: after an unsuccessful attempt to install new software, I have no communication with the Internet and can not reset the router to factory settings.
Expect some advice.
Credit: O. Boev
Es esta una buena pregunta?
Puntuación 0
1 comentario
Oghi Boev, when you say "attempt to install new software" are you referring to installing new firmware for your router? How did it fail? How did you try to do it?
- de
Agregar un comentario
3 Respuestas
Solución Elegida
You must connect to the router via Ethernet cable for setup/upgrade. If you pooched the upgrade buy a new router... software fixes/hacks are not really our thing here.
If this Answer is helpful please remember to return and mark it Accepted.
Fue útil esta respuesta?
Puntuación 1
La respuesta fue originalmente a otra pregunta.
Here's the Linksys support page for your unit WRT54GL Wireless-G Router It has all you should need to answer your questions.
Puntuación 0
Try by resetting your router and re-configure it again. Please note that your all saved setting shall gone once you have done hard reset so i would suggest if your using ADSL then get your PPPoE account setting from your ISP first and then do this.
Puntuación 0
Añadir tu respuesta
Oghi Boev estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 617
