Question about the fuel system?
Does the system use an oil injection device, or does the fuel have to be pre-mixed?
Es esta una buena pregunta?
The fa50 has a oil injection system
but older systems can be problematic - so pre-mixed could be an option
Fue útil esta respuesta?
As Markus already answered, the FA50 has an oil injection system. However, several users on Moped Army advise to bypass the oil injection system and just premix the fuel -- it will supposedly regain a bit of power lost from powering the pump.
I am looking into creating a guide for this procedure, but it will be a while before I get a chance to sit down and figure it out.
Het is mogelijk benzine en Olie 2takt vooraf gemengd te vullen in de benzinetank ? Gedaan En Wat Met De olieinjectie ?
well, my dutch is pretty rusty - but i'll try to answer that.
as miroslav stated. there are users on mopedarmy.com who are bypassing the oil injection. technically it should not be a huge problem - it's some kind of normal on other 2 stroke bikes (aprilia af1, rd350 and so on). but maybe mirsolav can tell you more about that.
Miroslav zoals gezegd, zijn er mopedarmy.com gebruiker op de pre-gemengde benzinetank en ontkoppel de olie-injectie
het is een soort van normaal op andere 2 takt motoren (Aprilia AF1, rd350, enzovoort). maar misschien mirsolav kan u meer vertellen over dat.
i hope that this is halfway understandable. i had a girlfrind who's mother was from the netherlands - so my duch is not the best - reading - no problem, but writing or speaking - aaargh -
I just bought two 1985 fa50s. Has old gas that needs to be drained. I had the same question regarding the mix. Also, does these babies have a fuel filter? Also, a oil filter? And what is a good oil to use?
Hi Ed , Here's are links to an owners manual and a service manual : http://projectmopedmanual.info/Manuals/S... ; http://projectmopedmanual.info/manuals/s... .
They are for 1980 , but all FA 50 s are pretty much identical , but for cosmetics . If you run the recommended oils , you'll have no problems .
Ultimas 24 horas: 4
Ultimos 7 días: 15
Ultimos 30 días: 37
Todo El Tiempo: 8,338
