Saltar al contenido principal
Una cámara digital compacta lanzada el 15/09/2005.
" memory is locked"
I have a similar problem with my SD450. What happens is that when I insert a 32gb memory card it always tells me " memory is locked". I've adjusted the little tab on the card but nothing works. ( I can use a lower gb card and it works okay)
John Allen
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
Solución Elegida
John Allen, make sure that you are using an SD card and not an SDHC. also, the camera was tested by Canon with 2GB cards only, so it is possible that your cameras firmware does not read 32GB, that would explain while your camera " can use a lower gb card and it works okay. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
John Allen estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 5
Todo El Tiempo: 188
