Saltar al contenido principal
iPhone 5 dead LCD after rear case replacement
I replaced a customer's iPhone 5 rear case today and now the LCD appears completely dead. The mute switch makes it vibrate so I know it's on but replacing the front didn't help (or a hard reset obv).
Could I have blown a fuse or what could be the problem?
The logic board doesn't appear damaged.
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
3 Respuestas
Solución Elegida
Mabe could you verify that the connectors are connected well and all the pins absolutely clean. It looks like your display is just not supplied/connected. Remind that even a small peace of dust can cut the connexion...
Hoping to have helped you,
Give us some feedback !
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Absolutely clean and connected :-/ I'll have a partner put it under a microscope today.
- de
Hi
Happened to me the same problem, what I did was to inspect well near the connectors and set me well that a connector had broken and what I did was I made a bridge with a silver writer. and it worked but I had to connect a new screen for it to work and then place the iphone screen.
And iphone is working properly
Bad Part
http://www.flickr.com/photos/99104195@N0...
Fixed with Silver Writer
i use a Macro Lens for iphone 5
Link Silver Writer
http://www.amazon.com/CIRCUIT-WRITER-SIL...
never use it direct the writer, put some on a sheet with something that has the fine point you can do it without touching other connectors or you can make a short circuit.
Puntuación 0
Hello Anders,
How did you fix it?
Puntuación 0
Añadir tu respuesta
Anders estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 822
