1. On the inside of the base is a long coiled spring. First hook this back over the end of the central drawer runner. Have a ruler or similar flat item handy to release it later.
If the mechanism inside the cash register has come apart, read paragraph 2. If not, go to 3.
2. Take the body of the cash register and insert the narrow end of the brown plastic lever through the white plastic assembly, until it engages with the handle mechanism. You will then feel resistance when turning the handle. There is a flat metal strip in the middle of the assembly. On the side of the brown lever is a small projecting peg. Put this behind the metal strip. Put the thicker end of the lever through the rectangular gap in the white assembly.
3. Place the drawer into the body of the cash register so that the back of it engages with the V shaped notch on the plastic lever.
Hold the drawer and body together with one hand and carefully lower them on to the base. While there is still a small gap under the drawer, insert the ruler to release the coiled spring. This will engage with the projection under the drawer.
Push everything together and replace the screws. Job done!
1 comentario
I know this is old, but just in case anyone else has this problem; the eyes of the spring attach to the two small pegs behind the two large ones. Just slip the loops on the spring over the tops.
- de Devyn Leigh
