Saltar al contenido principal
Repair and disassembly guides for Sony DVD players.
Preguntas 63 Ver todo
DVD player is not reading DVDs or CDs
Sony DAV-DZ690K
I own this four years old Sony Home Theatre system. I noticed recently, it is not reading either DVDs or CDs. When I insert a DVD, it takes a while to read, but shows 'No disc'. The tray simply opens on its own.
I appreciate your help to solve this problem.
Thank you so much in advance.
Narni
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 5
2 comentarios
Mine takes awhile loading then says can not play this disc.
- de
I wanted to know the spray that is used in cleaning of the lens inside the DVD
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Narni, sounds like either a dirty laser or a burned out laser. Try one of the commercially available lens cleaners. If that does not work you may have to disassemble your player and clean/replace the lens assembly. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
Thanks for the advise. I bought a lens cleaner and tried. The tray is just opening on its own. The player is not reading the discs.
Any advise is welcome!
- de
Thanks for the advise. I bought a lens cleaner and tried. The tray is just opening on its own. The player is not reading the discs. Any advise is welcome!
- de
Try another disc or try another drive to make sure which causes the problem. In most cases, it’s a scratched DVD or a dirty drive. This post has shown all the possible reasons and fixes.
Puntuación 0
Push power protector
Puntuación 0
1 comentario:
Push
Reasonpower protector not working
- de
Añadir tu respuesta
Narni estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 13,427
