Where exactly is the Flasher Relay for a 2003 Mazda Protege located?
Es esta una buena pregunta?
Berry, the Turn signal/Flasher relay is under dash on drivers side. If you have a manual transmission is is almost directly above the clutch pedal. It is a gray colored box about 2 inches wide by 4 inches long. It is #5 in the attached diagram.
Hope this helps, good luck.
Fue útil esta respuesta?
Thank You very much , it solved my problem.
Thanks
Ronald (Philippines}
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 23
Todo El Tiempo: 11,377
1 comentario
Thanks oldturkey03! I will check this out immediately.
- de Berry
