Saltar al contenido principal
Lanzado en 2006, identificado por el número de modelo E1705
video card not working need help locating same
video card does not work, it is built into the motherboard, or is it? Mine does not have a big video card as displayed in your pictures. There is a small green card plugged into the motherboard where it would appear the one you removed in the pictures. Is this little green card the actual video card ?
I have taken pictures if that helps.
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
Solución Elegida
Michael Crawford, that is a depends. "A removable (or discrete) video card is optional and present only if ordered by the customer. Standard video is integrated on the system board and is not customer removable." Download the service manual from here. It will help you to disassemble your computer, explain the parts to you, that way you will know what you have. you'll also find an excellent write-up on here. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Michael Crawford estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 258
