Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Modelo núm. A1367 / Capacidad de 8, 16, 32 o 64 GB
Restoring iPod that is disabled and also has a broken power button!
I'm in the possession of an iPod 4th Gen that has a broken power button and is completely passcode disabled.
Is there any possible way to restore it?
You can not use itunes as it will complain about the passcode and I cant manually put it in DFU mode as the power button is broken.
Programs such as Tiny Umbrella and Rec Boot will not recognise the device since it is passcode disabled?
Help... lol
Es esta una buena pregunta?
Puntuación 13
2 comentarios
I need a way to reset my ipod I am disabled my home botton does not work
- de
how to restore softwear without home button
- de
Agregar un comentario
6 Respuestas
Solución Elegida
Here you go mate
http://www.greenpois0n.us/2011/08/downlo...
Fue útil esta respuesta?
Puntuación 3
4 comentarios:
Great answer. I would upvote, but apparently there is a 50 per day limit.
- de
That makes no sence jack :/
- de
I just read into why Recboot was not working for me. Apparently it does not work correctly on x64 versions of Windows :/
- de
Not if you can't solder tho
- de
If RecBoot does not work, you need to replace the power button.
Puntuación 2
1 comentario:
Thought that may be the case
- de
Repairing the button will always be the straightforward solution
Puntuación 1
Hi Folks,
after struggling for 2hrs, I finally found the solution!
I had bought a disabled ipod G2 on an auction site... It looked impossible to unlock it! I couldn't go into the DFU after trying at least a hundred times (eventually, I found out that the home button is lazy...)!
Anyway, after re-reading the same procedure over and over, and working for a device manufacturer myself I was pretty sure there existed a SW only solution to do that (I can't imagine that people in the production need a roughly 30 sec procedure to flash a FW).
I eventually found it! it is called RecBoot. There are 2 versions, 1.3 seems to be the latest for Win7 32bits (the one I used) and there is another one for Mac which is already at v2.2. I loved those guys who made it! it took me about 30minutes to get my ipod working (I needed to reinstall itune)! (just load Recboot, choose the mode and plug the iphone/ipod in)!
Just google it and download it (about 700k).
Puntuación 1
3 comentarios:
thx!!!its working
- de
does this really work
- de
awesome, u save my live dude,, thank you very much
- de
recboot is awesome. thank you very much guys
Puntuación 0
If Recboot doesn't work, try to use Tenorshare Reiboot
Puntuación 0
Añadir tu respuesta
Tim Carruthers estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 33
Todo El Tiempo: 63,303
