Can the internal eMMC be replaced with a higher capacity?
I noticed that they only have an 8 GB Kingston eMMC chip onboard. What would it take to replace this with a 32 GB KE4BT5D6A Kingston eMMC chip?
Es esta una buena pregunta?
JaceRem, both chips are the same package and it appears as if the circuitry is the same. It will require a reball, for that you will need the solder balls, stencil and rework station. Of course you will also need firmware supporting the higher memory. Not an easy task nor is it inexpensive. May be a USB hub and a USB storage device might be a better way to go.
Fue útil esta respuesta?
You have to think for a negative impact, event you can replace for higher capacity , children and your time is wasted just because the game. please think again.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 14
Todo El Tiempo: 2,605
