Saltar al contenido principal
La Canon Powershot SD790 IS es una cámara fija digital compacta de 10,0 megapíxeles con flash incorporado y zoom óptico de 3x. Fue lanzada en marzo de 2008.
Preguntas 10 Ver todo
Card is locked. Help on holidays.
I used the camera yesterday and had no problems. Went to use it today and it says card is locked.
Es esta una buena pregunta?
Puntuación -1
2 comentarios
Did you check to see if it is locked?
- de
How do I know if its locked. Its my daughter in laws camera.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Debbie, check the slide switch on the memory card. Make sure it is not in the locked position. If that does not correct anything, check on here and see if any of those fixes are working for you. Hope this helps, good luck
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
Thanks for the help. That`s what the problem was. I would have never have thought to look at that piece. Thanks again for the help.
- de
You are welcome:-) glad I could help.
- de
Añadir tu respuesta
Debbie estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 410
