Saltar al contenido principal
IPad 2 GSM con 16, 32 o 64 GB de almacenamiento y un procesador Dual Core A5. Número de modelo A1396. La reparación es complicada y requiere calor y palanca.
Preguntas 152 Ver todo
Pregunta Cerrada
Why does iPad charge slowly (only 4% overnight) after repair?
I replaced the digitizer on my iPad 2 and it has caused some new issues. First, the iPad only charged 4% over night after the replacement. Secondly, the home button is only working intermittently. Lastly, it is randomly resetting itself when I plug it in.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
I would check your battery connection and make sure you didn't break or tear any connections or cables. I had a friend whose iPhone wouldn't charge and kept shutting off randomly because the battery wasn't properly connected.
And of course, here is the guide if you need help.
Reemplazo de la batería del iPad 2 GSM
Fue útil esta respuesta?
Puntuación 0
Solution Iphone 4 batter slow charge SOLUTION
Just go to settings > reset > 'reset all settings'
This is the solution to get the Iphone back to normal (quick) charging!! 100% worked for me after anoying 2 weeks of figuring out WHY it charged sooo slow! You won't lose data/contacts. Only WiFi passwords and some basic settings, but this is not a big deal compare to the slow charge problem! Success!!
Puntuación 0
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 1,020
