How to remove and replace charging port
I've seen the video and the teardown instructions. Unfortunately, they don't address the removal of the charging port from the board and replacement.I've purchased the replacement part, but the one in place does not move even when I apply force.
Has anyone done this? What is the trick?
Thank you. Bill E.
Es esta una buena pregunta?
6 comentarios
Did you try to unsolder it?
- de oldturkey03
No. It appears to be press fit. Is it soldered?
- de UpperNY
Did you get an answer - my USB port appears broken so it looks like a motherboard replacement unless you had some success?
- de duncan
I have a galaxy s3 charging port is broke how to change usb out
- de Steven
Because I'm afraid I will brake it if I dnt do it right how hot does solder have to be to brake the solder on usb charging port
- de Steven
Mostrar 1 comentario más
