Why my LCD screen has a single vertical pink line?
Why my lcd screen has single vertical pink line? It won't gone even though I has reset PRAM, wipe the screen pixel with hands.
Es esta una buena pregunta?
Chan Ricky, vertical lines on any LCD usually indicate a failure of the LCD panel. There is also a small possibility that this is caused by a faulty video cable itself. So check on that first. Of course, also check on an external monitor and see if it shows the same line, then you narrowed it down to the video card portion of your computer. Hope this helps, good luck.
Fue útil esta respuesta?
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 19
Todo El Tiempo: 3,486
