Saltar al contenido principal
The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
Preguntas 407 Ver todo
3 red lights flashing on my xbox 360
My xbox 360 has three flashing red lights and it will not show anything on my tv it says no signal what could be wrong with it please help me
Es esta una buena pregunta?
Puntuación 13
5 comentarios
I have the 3red rings on mine and my xbox fan is running. so im guessing my power supply is ok. i just dont know what's the problem with it
- de
I fixed my red ring of death
- de
Hey there! to make it easier for other people, How did you fix it?
- de
Mine also red-ringed. The same problem. Three of the four LEDs are lighting up red, however I suspect it has been “fixed” before by someone else. And it happened just today. How I figured the fact that it was “fixed” by someone else?
It has opening marks on the back already.
- de
Followed steps to the letter, 3 red lights still show whenever turned on
- de
Agregar un comentario
4 Respuestas
Solución Elegida
kim, you did not tell us which lights are red but I bet it is sections 1, 3, and 4 that are flashing red. This would be a "General Hardware Failure" Try this :"Check the secondary Error Code:
Try restarting the console.
If restarting the console does not resolve the behavior, follow these steps:
Turn the console off.
Unplug all the power and AV cables from the console.
Unplug the power cord from the wall socket.
Firmly reconnect all the cables.
Turn on the console.
If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
Also examine the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the RoL flash red." from here. If this did not resolve anything, it is time to either fix it yourself with these guides and parts, or have the motherboard professional reballed. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 6
didn’t work this is a scam
Puntuación 1
1 comentario:
wrong it works
- de
This problem occured to me suddenly today during a thunderstorm causing voltage to be incosistent.I tried restarting the console sometimes with no result. Afterwards i checked the power supply and its led was RED , i detached its plug from the socket and attached it again , the led became orange and once powering the console up , it became green and the xbox run as usual.
Puntuación 0
1 comentario:
doesnt work need to be true not a scam
- de
i fixed mine red ring of death no thanx to u
Puntuación -1
1 comentario:
And you didnt share HOW you claim you fixed it, so noone ELSE can fix theirs -->> so NO THANKS TO YOU EITHER!!!
- de
Añadir tu respuesta
kim estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 55
Ultimos 30 días: 307
Todo El Tiempo: 98,450
